October 27, 2016, 09:20 |
replace cfx scalable wall function
G Ionut
Rep Power: 9 |
I want to replace the scalable wall function used in the k-epsilon turbulence model, with my own wall function that I could use it for k-epsilon turbulence model. Until now i tried with user defined wall function (ch 4.2.4. User Defined Wall Functions) but it isn't working. How can I do it? Thank you |
October 27, 2016, 17:15 |
Rep Power: 143 |
What isn't working about it? That feature should do what you are looking for.
October 31, 2016, 10:24 |
#3 | |
G Ionut
Rep Power: 9 |
I am doing a test in a diffuser, and for the Wall Function Transfer Coefficient I entered a value of 5 [m/s], then I run the simulation. When I represent the velocity in the diffuser I have values from 0.2 to 1.4 m/s, shouldn't I have 5 m/s over the whole velocity? |
October 31, 2016, 13:56 |
Rep Power: 32 |
Not sure what is your understanding of the wall function concept. For the momentum equation, the wall function transfer coefficient relates the wall shear with the velocity at the wall and the control volume, i.e.
Wall Shear = WallFunction Transfer Coefficient * (Vertex Velocity - Wall Velocity) The analogy to heat transfer Heat Flux = Heat Transfer Wall Function Transfer Coefficient * (Vertex Temperature - Wall Temperature) Hope the above helps, |
November 1, 2016, 01:42 |
#5 | |
G Ionut
Rep Power: 9 |
Can you please give me some documents to learn more about it, or some web addresses? |
November 1, 2016, 16:50 |
Rep Power: 143 |
Any CFD textbook will have a chapter on turbulence modelling which covers this. Or you can probably find some descriptions of this stuff with a google search too - it should not be too hard to find.
cfx, user defined function, wall function |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
Scalable Wall Function | junz | FLUENT | 0 | April 18, 2015 21:32 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
