areas of no flow
Old   December 15, 1999, 07:39
Default areas of no flow
Eve Chapper
I am trying to create an area of no flow within a domain using CFX4.2 Build. I am investigating two approaches. The first is to define a solid area within the domain as a 3D solid patch. This has not been successful in creating an area of no flow. The second method is to subtract a solid from the domain for which I need a method. Any help is very much appreciated. Eve.
Old   December 16, 1999, 07:02
Default Re: areas of no flow
jy
Hello, I think you need to create the solids only where you will have a mesh. Then the surfaces will be walls, symmetry, inlet, outlets... Where you will make no calculation it not interesting to discretize (mesh). jy
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
What is the difference between liquid reactive flow and gas reactive flow? James Main CFD Forum 6 May 15, 2009 12:14
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
Plug Flow Franck Main CFD Forum 3 September 4, 2003 05:57
