Reynolds Stress Models
Old   February 1, 2000, 15:38
Default Reynolds Stress Models
Roued
Hi, every one
I have e general question about using the Reynolds Stress models (RSM and ASM) within CFX.
When simulating air flow in ventilated enclosures like a building or a room, the quality of the prediction made by the Reynolds Stress models are poor compared to the two-equations model like k-eps, low-Reynolds k-eps or the low-Reynolds k-omega models. (Comparing velocity profiles, between different turbulence model and experiments).
The flow is in general low-Reynolds (RE approx. 4000-5000). Room has slot inlet and outlet in full width of the room.
Why does the RSM make such a poor prediction ???
Any hints ???
Only standard parameter are used both in the Reynolds Stress Model and the other two-equations models.
Thanks in advance.
Best Regards
Roued
Old   February 2, 2000, 09:45
Default Re: Reynolds Stress Models
ahmadreza hosseinkhani
hi dear friend probably, you must be use the near wall corrected R.S. model
thank you
a.r. hossenkhani Ph.D. student of hydraulic civil eng.
Old   February 7, 2000, 10:33
Gita
Hi Roued,
Is your question about RSM within the context of CFX or in general? If it's general and you want to know why RSM is poor compared to other models, then I can share some of my knowledge with you. I have used CFX once and I don't remember it now(as I don't have the code). I had a course in turbulence and during that time I came to understand some of the aspects of turbulence. The very basic deficiency of RSM is the "closure". We don't have any clear physical understanding of the problem in concern in order to close the unknowns that RSM introduces thro' averaging. That's why it works well for some problems and fails in some others. gita
New implemented algebraic Reynolds stress model volker OpenFOAM 13 October 21, 2013 00:01
Reynolds Stress Models Jade M Main CFD Forum 0 April 21, 2010 16:38
Compressible Reynolds Stress Models cosimobianchini OpenFOAM Running, Solving & CFD 0 August 24, 2007 06:13
Reynolds Stress Models amelia OpenFOAM Running, Solving & CFD 1 August 11, 2005 17:12
Reynolds Stress Models Roued Main CFD Forum 20 February 8, 2000 02:58
