February 11, 2017, 12:23 |
No Static Entropy Generation
Giacomo Mingardo
Rep Power: 9 |
Hi everybody,
I'm doing a simulation at very low RE number (1e4) and very low velocity. the simulation is also with no heat exchange and incompressible flow, so I'm using the Isothermal model. In the solution there is no entropy rise, as the Static Entropy in the Post is 0 everywhere. However, the viscosity effects in the simulation are well captured, as I obtained a total pressure distribution verified with experiments. So basically everything seems to work, but the entropy is not calculated. Do you think it's a problem? Thank you a lot, Giacomo |
February 13, 2017, 08:49 |
Rep Power: 16 |
Consider the definition of entropy : dq=Tds.
Your isothermal condition falls to isentropic. |
error: uninitialized local variable 't' used | MASOUD | Fluent UDF and Scheme Programming | 5 | October 17, 2016 04:24 |
fprint problem | MASOUD | Fluent UDF and Scheme Programming | 5 | October 30, 2011 16:08 |
defining a term for a domain using DEFINE_ADJUST | MASOUD | Fluent UDF and Scheme Programming | 1 | September 24, 2010 05:08 |
enum | MASOUD | Fluent UDF and Scheme Programming | 0 | June 5, 2010 00:49 |
Entropy Generation in compressible flow | Dave | FLUENT | 0 | January 5, 2004 07:12 |
