March 15, 2017, 20:31 |
Heat transfer in a Furnace
Wanderley Grespan
Rep Power: 9 |
Hi guys. I need a help. I'm not so good on simulations but I trying.
This is a furnace, and inside there's a cylinder (Steel) initially with 480°C and it will be cooled. There's 12 inlets with a mass flow(air) and only one Outlet and I want to know how is the decreasing of the temperature along the time. I have considered only heat transfer by convection. At the images you can see some of the settings that I did for solving the problem. And I need to know: Can I trust the results? If I can, how much? Apparently I don't have to many knowledge about time steps and convergence and for this reason I ask your opinion about what I did and what I can do different. Please, it will be very helpful for me. Thanks!!! |
March 16, 2017, 03:56 |
#2 | |
Rep Power: 143 |
First of all read this FAQ: https://www.cfd-online.com/Wiki/Ansy...gence_criteria In this simulation you clearly have a large separation in time scales. The solid domain is much slower than the fluid domain. So use a solid time scale factor to accelerate convergence in the solid domain. A factor of 10, 100 or 1000 should do it. |
March 16, 2017, 05:07 |
Time Step.
Wanderley Grespan
Rep Power: 9 |
You are right Gleen. My time step it's not good.
But Can you se the other settings? I forgot to post before. Can you give me more ideas and tips for solving the problem. How I said before, I'm still leaning and it will be very helpful |
March 16, 2017, 05:21 |
Rep Power: 143 |
Oh, I see your simulation is transient. In that case forget about the solid time scale factor suggestion. That only works steady state.
For CHT simulations you should include imbalances as part of your convergence criteria. Unless you have done a time step sensitivity check your time step will be wrong. Instead I recommend you use adaptive time stepping, homing in on 3-5 coeff loops per iteration. Make sure the minimum and maximum are wide enough you never hit them. Also the initial time step needs to be sensible. Then the solver will automatically find its own time step size. |
March 16, 2017, 06:13 |
TimeSteps
Wanderley Grespan
Rep Power: 9 |
Following your tips about the adaptive time step, I must say, i've never used this option and for this I don't have knowledge of how I supposed to do.
What do you recommend for those options? |
March 16, 2017, 06:17 |
Wanderley Grespan
Rep Power: 9 |
Do you have any comment about my fluid models tab (turbulence model)??
March 16, 2017, 09:37 |
Erik
Rep Power: 23 |
It really seems like you should do some of the CFX tutorials. They are very beneficial and you will learn all that you are asking.
Instead of modeling those little inlets, I would have used source points injecting fluid, but that's besides the point. You need to go over the tutorials. |
March 16, 2017, 11:05 |
#8 | |
Wanderley Grespan
Rep Power: 9 |
"Some of the CFX tutorials." Can you be more specific about what tutorials you are talking about? |
March 16, 2017, 17:53 |
#9 |
Rep Power: 143 |
All of them
If that is too much for you then look through the list and do the ones which look relevant to you. |
convection., heat transfer modelling, time steps, transient analisys |
Heat transfer using all modes | bhups45 | FLUENT | 0 | June 19, 2016 07:02 |
Question about heat transfer simulation | Anna Tian | Main CFD Forum | 0 | January 25, 2013 18:53 |
Heat Transfer in Porous Medium | eryan | STAR-CD | 0 | September 28, 2010 13:14 |
Question on heat transfer coefficient!!! | Benny | FLUENT | 7 | June 7, 2005 09:25 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
