March 22, 2017, 23:09 |
LES of vortex rope in the elbow draft tube
LintaoZhong
Rep Power: 9 |
Hi guys
I am trying to predict and analyze vortex rope in the elbow draft tube by means of CFX. I read some literature and follow the guides in ANSYS Help about Large eddy simulation, but there are some issues happened to me. I can't sure whether it's error settings in CFX or bad initial conditions. So I need everyone's help. (1) Should I choose DES rather than LES for analyzing vortex rope? I noticed that the difference between LES and DES is adjacent wall resolves, one use DNS and other use URANS. Main flow play a important roles in vortex rope, so whether I shouldn't spent so many time to resolve wall regions used LES. (2) What's reason causing my residual surge like below figures, time step, the size of mesh or anything else? As below figure shows, residual is fastly convergence at first steady caculation and then, at transient caculations, it occurs so peaks with the increasing of residual. Is it correctly? Lintao In addition. are there anyone could give me one tutorial about LES in CFX. I don't sure whether my CFX settings is correct. Thank you very much Last edited by Sergeyevichsky; March 23, 2017 at 02:12. Reason: upload figures |
March 23, 2017, 00:24 |
Rep Power: 143 |
DES is used for flows off bluff bodies. LES is used in general turbulent flows - so I think you will not be able to use DES. But check the theory behind it to confirm this.
You are correct, it is likely the detailed wall effects are not important in your flow. This will make the model easier. Can't upload figures? FAQ: https://www.cfd-online.com/Wiki/Ansy...n_the_forum.3F |
March 23, 2017, 01:48 |
#3 | |
LintaoZhong
Rep Power: 9 |
March 23, 2017, 05:45 |
Rep Power: 143 |
There is LOTS of literature on using LES to model vortex flows in industrial cyclones. This has very similar physics to what you are talking about. So I would do some literature study before you start, and you should find lots of relevant stuff on industrial cyclones.
March 24, 2017, 04:50 |
#5 | |
LintaoZhong
Rep Power: 9 |
Vortex Tube Mesh and Simulation in Fluent | sankeerth2292 | FLUENT | 2 | March 13, 2015 22:52 |
Animiation of vortex tube? | wanghaojie | FLUENT | 0 | October 11, 2013 11:13 |
Hydraucone Draft Tube CFD | tojoe999 | OpenFOAM | 0 | March 5, 2012 13:10 |
Gas flow in vortex tube - LES and grid resolution | bernarde | Main CFD Forum | 1 | March 26, 2009 10:50 |
Draft tube and MFR/SG | nyatoto | CFX | 0 | June 3, 2003 05:55 |
