HELP!!TWO PHASES FLOW
Old   July 18, 2001, 20:49
Default HELP!!TWO PHASES FLOW
dingding
Hi,everyone!
I am simulating the oil-water two phases flow. I set two inlets at LOW I of a block, one is oil water inlet and another is water inlet.
I use the homogeneous model to simulate the free surface between the oil and the water. The problem is that U, V, MASS and VOLUME FRACTION of each phases don't convergence, in addition, no free surface in the CFX-analyse, why? I used a single water compuation as the START dump file, but no free surface being found!
Please help me! Thanks in advance.
Old   July 19, 2001, 23:52
Default Re: HELP!!TWO PHASES FLOW
De-Wei Yin
Check the initial guess. If you don't specify the initial phase distribution, the solver defaults to 50% oil and 50% water. See CFX-4 Solver Reference Example 29 (provided with the software).
Old   July 20, 2001, 00:45
dingding
hi, all
I have set two inlet.
One inlet is oil , oil velocity is 0.01m/s and volume fraction is 1.0. At oil inlet, water velocity is 0 and volume fraction is 0.0.
Another inlet is water, water velocity is 0.01m/s and volume fraction is 1.0. At water inlet, oil velocity is 0 and volume fraction is 0.0.
I use the laminar model to simulate this transient flow, but there are the same problem.
please help me!
Old   July 20, 2001, 04:31
Jon
I would set the inlets as both the phases having the same velocity, but different volume fractions.
How have you set up your fluids? Let me know what kind of problem you are trying to simulate (i.e. free-surface, disperesed particles) and then tell me how you have set up the fluids (continous/dispersed) and which multi-phase models you are using.
Also, the initial conditions will be important w.r.t. the type of simulation you are perfroming and the 'true' physical initial conditions.
Jon
Old   August 6, 2001, 03:59
Fred
Hello
I agree with Jon's answer.
You have to put the same speed for the two components but different volume fraction ->inlet_oil : oil_speed=0.01 / oil_vf =1
water_speed=0.01 / water_vf=0 ->inlet_water il_speed=0.01 / oil_vf =0
water_speed=0.01 / water_vf=1
If you are using a transient simulation, and using a restart with a dump file, the command "initial guess" overwrites all the existing field.
Excuse me for my poor english.
Regards,
Fred
Mass flow and U-Mom flow in CFX Zhihua Xie CFX 0 September 3, 2007 09:49
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
How to change from mass flow to volume flow rate stanley FLUENT 1 February 2, 2007 06:44
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
Plug Flow Franck Main CFD Forum 3 September 4, 2003 05:57
