April 23, 2017, 07:51 |
How to angle coordinate frames?
Dain
Rep Power: 9 |
Hi all,
I have created two coordinate frames around a hub which is slightly angled but when I assign these frames they both point vertically, which I am not sure how to change. I have tried looking at Eulers rotation angles but I am not sure if I am looking in the right direction to solve this problem. I have attached a picture for a visual representation. I am quite new to Ansys so I am learning as I go, but if someone could point me in the right direction on how to get these so they are in the right orientation, then that would be fantastic. Thanks! |
April 23, 2017, 19:19 |
Rep Power: 143 |
When I look at those green vectors I see one is leaning left by a few pixels and the other is leaning right by a few pixels. So they appear to be off parallel by a small amount. Isn't this what you intended?
April 23, 2017, 23:24 |
Dain
Rep Power: 9 |
Thanks for replying, but they should be on a 5 degree angle and parallel, I am not sure why they are in different directions. Is there a way I can manually set the direction?
April 24, 2017, 04:23 |
Rep Power: 143 |
The perspective view in CFD-Post does distort angles a very small amount. You are probably seeing that distortion.
coordinate axes, coordinate frame-, workbench ansys 17 |
Moving Coordinate Frames in Post | robo | CFX | 0 | October 2, 2015 11:06 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
Normal vector, slope and aspect angle | g_niro | Main CFD Forum | 0 | February 2, 2011 17:24 |
Source terms in local coordinate frames | CF | CFX | 2 | August 29, 2006 02:30 |
Transfromation between different coordinate frames | P.Fonteijn | CFX | 0 | October 5, 2001 09:35 |
