April 25, 2017, 23:01 |
Fatal Error ( cannot run CFX
Ron
Hi , I am using the 17.2 version, Vista 32 bit. When I try to run the CF. I only get error message:
"The application has encountered an unexpected problem and will now terminate: Aborting due to unexpected error: comm::error: AppWindow::initialize - Error waiting for viewer connection from engine: Please report this error, along with the circumstances in which it occurred. The following information may be useful to CFX support: Unexpected error: Aborting due to unexpected error: comm::error: AppWindow::initialize - Error waiting for viewer connection from engine:". another message: "System.InvalidOperationException: Application has terminated before command could be sent. at Ansys.CFX.Foundation.App.CUEApplicationProxy.SendC md(String code, String data, Int32 maxWait, Boolean ignoreCUEErrorDuringSendCmd) at Ansys.CFX.Foundation.App.CUEApplicationProxy.Start CommandBlock(Int32 timeout) at Ansys.CFX.Foundation.App.CUEApplicationProxy.Comma ndBlock(Int32 timeout) at Ansys.CFX.CFDPost.Data.CFDResultsSource.LoadEditor Data(IFullContext context, Boolean interactive, Boolean dedicated) at Ansys.CFX.Foundation.Data.CUESourceDataObject.Edit (IFullContext context, Boolean interactive) at Ansys.Core.Commands.Concurrency.CommandWorkUnit.ex ecuteInContext(CommandContext subContext, IExecutionEngineCallback tracer) at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExe cute(IExecutionEngineCallback executionEngine, CommandContext subContext) at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execu te(IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions) --- Ansys.Core.Commands.CommandFailedException: Application has terminated before command could be sent. CommandName: CFX.EditResultsAnalysis(Container="Results 1") at Ansys.Core.Commands.CommandAsyncResult.Wait(Int32 milliSecondsTimeout, Boolean exitContext) at Ansys.CFX.CFDPost.Commands.EditResultsAnalysisComm and.InvokeAndWait(IProtectedContext context, DataContainerReference Container, Boolean Interactive) at Ansys.CFX.CFDPost.Commands.EditResultsAnalysisGui. Invoke(GuiOperationContext context) at Ansys.UI.GuiOperationContext.Invoke(GuiOperationMe taData operationData) at Ansys.UI.UIManager.InvokeOperationCore(String pseudoname, OperationDelegate callback, Boolean allowOSMessages, Boolean coreTransaction)" Does someone know where could be problem? How should fix this problem? |
April 26, 2017, 03:03 |
Maxim
Rep Power: 12 |
What exactly did you do when that message appeared?
Have you tried restarting your windows and starting CFX again? Can you update to a newer windows version (and newer CFX version)? I don't think Vista, and even worse: 32bit, is supported... |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
CFX Transient Run in Workbench - not updated | asims | CFX | 0 | July 10, 2015 05:05 |
Can workbench and cfx run correctly on vista? | Sandam | CFX | 1 | December 2, 2007 16:32 |
Minimum number of nodes to run CFX in parallel | Rui | CFX | 3 | April 11, 2005 20:46 |
