Hi, all,
I am trying to use a X-win32 to run Tascflow on a SGI machine. however, I constantly run into the following message when I open the Tascflow: X Error of failed request: BadName (named color or font does not exist) Major opcode of failed request: 45(X_OpenFont) Serial number of failed request: 1291 Current serial number in output stream: 1317 The serial numbers are different each tine when I run Tascflow. Please help. Thanks a lot. Alex. |
Do you try to visualise your SGI-machine on a Windows-machine? Then make sure you set 'pseudo-color' somewhere in your config nemu.
If this doesn't help, call your local CFX-representatives. They should know. Astrid |
Thanks,
I enabled the Pseudocolor mode on the X-Config, the same thing happened. Also, I enabled the debugging on in the message box, then the following message show up: "-adobe-helvetica-medium-o-normal--14-140-75-75-p-78-iso8859-1" opened "-*-helvetica-medium-r-normal-*-14-*-*-*-*-*-*-*" opened "-*-helvetica-bold-r-normal-*-14-*-*-*-*-*-*-*" opened "-*-helvetica-medium-r-normal-*-10-*-*-*-*-*-*-*" opened "-*-symbol-medium-r-normal-*-14-*-*-*-*-*-*-*" opened "-*-symbol-medium-r-normal-*-16-*-*-*-*-*-*-*" opened "-*-courier-medium-r-normal-*-14-*-*-*-*-*-*-*" opened "-adobe-courier-medium-r-normal--20-*" failed It sounds that I don't have a type of Adobe font in my computer, is that right? Then How can I get those fonts. Thanks again. Alex |
ICEM CFD Prism Mesh Generation Problem with Ansys 12.0 & windows 7 OS | kh_thakor | ANSYS Meshing & Geometry | 1 | February 1, 2011 20:22 |
can we see foamToTecplot360 data in windows or we should install it in linux? | anijdon | OpenFOAM | 2 | January 4, 2011 11:45 |
UDF compiling problem in Windows | Mazyar | FLUENT | 1 | April 26, 2006 01:48 |
[OpenFOAM] Who help to give a instruction how to install paraFoam correctly | liugx212 | ParaView | 0 | April 17, 2006 15:32 |
PVM RSH parallel setup problem Windows XP | abe | CFX | 11 | January 30, 2006 05:10 |
