Local coordinates usage & use of expression editor
Old   November 21, 2001, 10:34
Default Local coordinates usage & use of expression editor
Veebs
Hi CFX 5.4 users, I am solving a cavity problem (axisymmetic, so having one cell in theta direction) with CFX 5.4. Top bounding surface and bottom bounding surface are rotating at different rpm. So I need to model with stationary frame. Do define Wall BC, I followed two methods and having problem with both. Please advice
1. representing the tangential velocity in terms of Vy & Vz (my axis of rotation is X). While doing that, I calculated angle using atan function using expression editor. Now while postprocess I find some radial velocity at the walls. This looks like due to the angle it finds is more like cell centered rather than for the particular node. Even if I view with hybrid results, wall velocity components are not correct.
Please let me know your thoughts on this ?
2. When I use a local cylindrical coordinate defined and represent velocity as Ur, U_theta, & U axial, the resulting velocity is simply Vx = 0, Vy = 0 & Vz = U_theta we have specified. Where we expect some component in the Vy also. Is there any limitations on using these options ?
Thanks for your time Veebs
Old   November 21, 2001, 21:39
Default Re: Local coordinates usage & use of expression ed
Robin Steed
Hi Veebs,
Post your CEL expressions for Vy and Vz.
Robin
Old   November 21, 2001, 21:55
VEEBS
Robin, Following are the equations used. bomega = 2*3.1415*10584 /60 [s]
tomega = 2*3.1415*27634 /60 [s]
angle = atan(z/y)
radii = sqrt(z*z + y*y)
vbtheta = bomega*radii
vzb = vbtheta*cos(angle)
vyb = vbtheta*sin(abs(angle))
vttheta = tomega*radii
vzt = vttheta*cos(angle)
vyt = vttheta*sin(abs(angle)) As my domain is in 2nd quad, I need to keep both components positive to get clockwise rotation.
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
