Y+ Value Plotting in CFD Post
Old   May 28, 2017, 10:14
Default Y+ Value Plotting in CFD Post
AS_Aero is on a distinguished road
Hi
Is there any way that we can plot the y+ value along our geometry ? When I do a plane and take its contour for y+ in CFD post I can see the value from 0 to 25 but the contour remains grey plane. There its not showing where these values are. So I am not sure where is 25 where is around 0 !! So what is the possiblity ? Also I want to see the log law and z+ values. How can we do these ? Kindly let me know.
I did K-W model and for that y+ have to be less than 1
and for LES WALE model what is the y+ criteria ?
AS_Aero is offline   Reply With Quote
Old   May 28, 2017, 18:36
Default tick; new var
Svetlana Tkachenko
Светлана is on a distinguished road
In the tree view at the left, tick the box next to the contour. If this does not help please attach a screenshot.
To create new variables, use the expressions and variables tabs at the top. Create expression first and then create a variable which uses that expression as the formula. There is a tutorial about it here: CFD-Post tutorial - Step 15: Create a Custom Variable and Animate the Display.
Светлана is offline   Reply With Quote
Old   May 29, 2017, 02:45
Hi
I did it and still it was grey. But when I select the wall option in the contour I can see the y+ along the wall.
Old   May 29, 2017, 07:31
D. N. Venturi
venturi is on a distinguished road
By definition, Y+ is only calculated at the wall. That is why you'll only be able to see it in the walls. The plane is gray because there is no Y+ values for the inner cells.
venturi is offline   Reply With Quote
Problem in CFD -post pratikvn ANSYS 4 March 21, 2018 02:56
Post-processing star ccm+ results in Ansys CFD Post sidharath STAR-CCM+ 4 April 10, 2017 11:49
Post processing in CFD Post or Fluent. Blobs OpenFOAM Post-Processing 2 June 26, 2016 07:23
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 19, 2015 23:40
CFD Online Celebrates 20 Years Online jola Site News & Announcements 22 January 31, 2015 00:30
