May 30, 2017, 02:52 |
Periodic heat transfer-CFX
AKS
Rep Power: 14 |
Hi.
I want to model periodic heat transfer problem in a circular channel with uniform wall temperature, say 330 [K]. IN CFX, I am able to achieve the periodic flow using either a source term in the momentum equation/ by specifying mass-flow rate. However, when I want to model heat transfer using source term I get weird results. Can anybody put some light on the source term for the energy equation. It appears to me that this setting does not solve the periodic temperature but a full flow (includes similar setting like uniform temperature at inlet. |
CFX Multiphase - Fluid-fluid heat transfer | nasir | CFX | 3 | June 15, 2014 18:44 |
CFX Multiphase - Fluid-fluid heat transfer | nasir | CFX | 0 | June 14, 2014 06:21 |
CFX wall heat transfer coefficient | mactech001 | CFX | 1 | January 5, 2010 21:33 |
CFX doesn't continue calculation... | mactech001 | CFX | 6 | November 15, 2009 21:25 |
