about accuracy of the CFD
Old   August 30, 2002, 12:24
Default about accuracy of the CFD
Hannah liang
Hi, friends, do you compare the result of CFD with practical situation? I want to know how big difference between them because I often meet the situation in which I have to get the practical pressure drop of the products from CFD simulation and i always received some doubt from that.Thanks for some infomation.
Hannah
Old   August 30, 2002, 14:40
Default Re: about accuracy of the CFD
Jan Rusaas
I think you can get many different answers to that. It depends on how well you do your calculation, You actually have to do a calculation with three grids and make a grid convergence study. From the pressure drop for each case you have to check if they are within the asymptotic range. When that is fullfilled you can do a Richardson extrapolation of the pressure drop and get a realistic guess on the pressure drop. While you do that you also have to check that you use the correct turbulence model and check your Y+ values. When I compare the pressure drop I calculate I often get results that are say +-25% from values in handbooks - but on the other hand how accurate are the values in the handbooks. I think I could write another half page about inaccuracy in measurements.
I do think that people that are measuring almost make as many mistakes as people doing CFD. Remember that there are errors/deviations in a CFD calculation, but the user is the factor that probably introduces the larges errors ))))))
Sorry, probably not very helpful answer, but interesting question. Jan
Old   August 30, 2002, 16:03
Hannah liang
Hi, Jan, do you think, generally, Y+ should be within the range of 11 to 300? In cfx, if Y+ is much higher(I mean higher than 300), it seems that the mesh should be refined. Is it?
Hannah
Old   September 3, 2002, 01:34
Dimitris
Actually from what I''ve been reading, a Y+ value as high as 300 at some regions of the model is a bit too high I think.
Old   September 3, 2002, 10:46
Jan Rusås
I think Y+ should be in between 30 and 100, but it depends on your problem. If you have a problem which is wall dominant then you might need y+ <=1 or other value depending on model. On the other hand if you have a system where the wall does not have any impact on the flow , at all - then I guess Y+ could be above 300. Jan
Old   September 3, 2002, 11:26
Robin
Hi Hannah,
Y+ is a good general indicator and should be below 100 for the scalable wall functions or between 11 and 100 for standard wall functions.
For some very high Reynolds number flows, such as around a ship hull, a high Y+ value is acceptable. The most general rule is that you should have at least 5 nodes in your boundary layer for the k-e model wall functions. Thus, if you create a vector plot intersecting your boundary, you should see at least 5 vectors increasing in magnitude before you hit free-stream values. If this is not the case, you should increase your near-wall resolution.
Regards, Robin
CFD accuracy Mohaba CFX 9 April 26, 2002 04:38
is there any money in CFD? T Main CFD Forum 35 May 9, 2001 19:35
CFD for fans & blower housings David Carroll Main CFD Forum 8 August 24, 2000 17:25
PC vs. Workstation Tim Franke Main CFD Forum 5 September 29, 1999 15:01
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
