Text with timestep in plot
Old   September 19, 2002, 02:48
Default Text with timestep in plot
Jens
Hi
I am doing plots of evolving flow and would like to have different plot with the current time on each plot.
It is possible to make a text saying what timestep it is, without having to make this manually each time I go to a new timestep ?
Like in Fieldview you can specifiy that the text string should include the current timestep number.
Thanks
Jens
Old   September 19, 2002, 05:07
Default Re: Text with timestep in plot
Bob
Jens, you should be able to do this in perl in post using the power syntax. This is something I haven't done myself yet, but I'm fairly sure you can do it ! Dave
Old   September 19, 2002, 22:08
Robin
If you take this approach, you can only write out the individual pictures and will have to create the MPEG with another tool or run the MPEG encoder manually. A good application for creating movies from pictures is Apple's Quicktime Pro (US$30) from www.apple.com/quicktime.
Robin
Old   September 20, 2002, 04:54
Bob
Robin, do you know if the inclusion of such a facility (anotate time step) will be included in a later version of post ?? Dave
Plot on a curve Monica FLUENT 1 July 11, 2012 00:24
Transfer low-res graphic file plot to excel plot quarkz Main CFD Forum 3 April 9, 2009 13:54
Plot variable vs timestep Sans CFX 3 May 29, 2008 18:55
plot in file with journal (text commands) Asashi FLUENT 1 August 21, 2006 07:08
graph plot anindya Main CFD Forum 2 September 17, 2003 12:00
