Boundary Condition
Old   October 28, 2002, 10:45
Default Boundary Condition
Carola
Hi Guys!!, I´m triying to especify in a cylindrical surface, a inlet flow with a angle respect to a normal vector of this surface. Should I create a new coordinate frame?,What i have to do?.
I´ll appreciate any help!!
Old   October 28, 2002, 13:29
Default Re: Boundary Condition
Sharks
Hi Carola
Assuming you're using CFX-5, you can specify a local coordinate frame whose Z axis is the axis of the cylinder. Then you should be able to specify velocity components as a function of angle (theta) about this axis.
Regards
Sharks
Old   October 28, 2002, 15:10
Carola
Hi Sharks!!, I wasn´t specific enough, I did a slice to this cylinder, this slice has a angle respect to the Z axis of the cylinder. I want to place the inlet condition on this slice (velocity), this vector velocity has a angle respect to the normal of the slice.
What can I do?
Regards
Old   October 30, 2002, 20:49
Sharks
Hi Carola
OK, I think I understand now.
You should be able to define a coordinate frame which has one principal axis (e.g. X) aligned at an angle from the slice plane normal.
When you specify your velocity vectors for the inlet boundary condition, select this coordinate frame (e.g. Coord 1) to be your Reference Coordinate Frame for the Boundary Condition. Any vectors you specify will then be in this frame, with
U = U|xref, V = V|yref, W = W|zref
Is this what you need ?
Regards
Sharks
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 05:05
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 03:23
How exactly the "pressure outlet" bdry condition compute properties on the boundary? yating9901 FLUENT 3 June 28, 2010 12:26
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 11:44
