Xilef Smith
Rep Power: 9 ![]() |
Hi all,
Im trying to import a simple 2D geometry (3.5m x 50m) into ICEM but it keeps giving me an error. I made it in Rhinoceros so I tried both .3ds and .stp, both not working. Can someone help me out please? Cheers! |
Rep Power: 143 ![]() ![]() ![]() ![]() |
Showing the error message would help....
Try other import formats as well. There are many others to try, such as IGES and parasolid. |
Xilef Smith
Oh right..so when I try to import a .stp file through open geometry I get: no such command: ISO-10303-21;
error in Baseline V1 2D Aerodynamic shape.stp can't read surface model When I go to Import model and import the .stp file I get: an internal error has occured - no tetin base available Any idea? Cheers If all else fails I'll try to create a .tin file? |
Try all the formats, not just one or two.
You appear to be importing 2D surfaces. Make sure you have the options set up to allow importing of surfaces (by default most accept solids). |
Xilef Smith
Thanks alot, it worked. I thought the geometry only consisted of points and curves and didn't click to import surface. Quite stupid. I hope it does not influence the simulation.
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
