Noman Hafeez
Rep Power: 8 ![]() |
how we can calculate the time step and total time for tidal turbine?what do you mean by turbine rotates 1 degree or 2 degree during each time step?is there any formula for time step and total time?
And what should be the convergence criteria for transient simulations? |
Rep Power: 143 ![]() ![]() ![]() ![]() |
Total time: That should the time required to get the results you need. So this is entirely up to you:
Time step size: Use adaptive time stepping, homing in on 3-5 coeff loops per iteration and you don't need to calculate it, CFX will find it automatically. Convergence criteria: Do a sensitivity analysis and work it out. It is different for different simulations so you have to find what is required in your case. While you are at it, do a sensitivity analysis on mesh size as well. That is the other important tunable parameter for accurate results. |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
time step directories naming issue | Andrea_85 | OpenFOAM | 3 | April 3, 2014 08:38 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
calculation diverge after continue to run | zhajingjing | OpenFOAM | 0 | April 28, 2010 04:35 |
