Porous domain energy calculation and specific heat capacity temperature dependent
Old   November 28, 2017, 12:27
Default Porous domain energy calculation and specific heat capacity temperature dependent
VB
Vishnu_bharathi is on a distinguished road
Hello people,
I have a simple model where porous domain is inbetween two fluid domains. Hot fluid is given as Input. I am using Specific heat capacities for fluid and solid material in porous domain to be temperature dependent. Also the density of fluid is temperature dependent. Energy calculation formula used 'Integral over (mass_flow*C_p*DeltaT )dt. Is there a way to calculate C_p for each cell?(in ansys cfx pre or post).
The opearating temperature range is about 800°C, so I do not want to take single average C_p value as it varies quite significantly between the temp range and compromises the Energy calculation.
In function Calculator I tried Function:volumeInt , Location: porous, Variable:Specific Heat Capacity at Constant Pressure. What volumeInt(SHC)@Domain returns actually?
Ultimately I need to calculate Energy in porous region/solid, where it is calculated using C_p that is temperature dependent. Any suggestion?
Vishnu_bharathi is offline   Reply With Quote
Old   November 28, 2017, 16:29
In the material model make Cp/specific heat a function of temperature. It is simple as that. But be aware that if you are specifying density as well you need to make it thermodynamically consistent across the temperature range.
Old   November 28, 2017, 16:45
VB
Hi. What do you mean by make specific heat, a function of temperature in material model? I have specified Cp as temperature dependent in expression -CFX Pre for porous solid domain but I am sure you are not specifing this, are you?
I have completed my simulation run using C_p of Porous domain as temperature dependent(C_p is temperature dependent for both solid and fluid materials in porous). I need the formula 'Integral over (mass_flow*C_p*DeltaT )dt for Energy calculation in porous domain where C_p is not constant. To put in other way, Is there a way to access C_p during each iteration/each node so that energy of total porous domain is calculated at each time step or at the end of simulation, either one is fine?
Old   November 28, 2017, 16:54
Opaque will become famous soon enough
Not clear what you are trying to compute?
When working with varying specific heat capacities, you are better off using energy quantities directly than simplified formulas unless you want to keep the thermodynamics consistency yourself.
For example, the integral over volume of static enthalpy, i.e. volumeInt ( density * static enthalpy)@Volume of Interest
Opaque is offline   Reply With Quote
Old   November 28, 2017, 17:06
VB
Hi. I need to calculate Energy contained in porous domain after my simulation or during the run, either one is fine. "you are better off using energy quantities directly than simplified formulas" - I would love to keep it simple . The formula that I mentioned is used to compute Energy in each node and in turn the whole domain. (eg., in Open foam or similar software where we have access to each node/cell in a domain, unlike Ansys). I believe Ansys is even simpler and accurate in Energy calculations over interested domain. What this returns? "volumeInt ( density * static enthalpy)@Volume of Interest"
Old   November 28, 2017, 17:12
Erik
evcelica is on a distinguished road
Pay attention to this, you can't specify both density and specific heat as variable unless you are very sure you have no thermodynamic inconsistencies.
Ways to get around this include:
Use the Boussinesq approximation for buoyant flow,
Use the ideal gas model,
Use a real gas model
Use an RGP table.
You can get some weird stuff happening with the energy equations if you specify both density and Specific heat and functions of temperature.
evcelica is offline   Reply With Quote
Old   November 28, 2017, 17:25
VB
Use an RGP table.
Hi Evcelica, Thank you for the suggestion. I have defined density and specific heat in such a way it does'nt behave weird in the temp range. I believed so. now the simulation has been completed. How do you calculate Energy in each domains now? I need this Energy value to cross check and few other stuffs.
Old   November 29, 2017, 04:29
Default VolumeInt , Energy
VB
Update: In order to verify this expression before using in Porous domain: I used volumeInt(density*static enthalpy)@my domain and compared with Energy calculated by m(mass)*C_p*dt. Both have difference. Why do I have difference here? Note: Here, the domain has constanct specific heat capacity and density, its a solid domain.
Old   November 29, 2017, 10:15
What is the reference temperature of the solid material definition?
Static Enthalpy = Integral from Tref to T of (Cp dT).
It is only
Static Enthalpy = Cp * (T - T_ref)
uniform Cp
Simplicity is plagued by the assumptions along the way. Assumptions are usually forgotten or implied and violated.
Old   November 29, 2017, 13:24
VB
I formula volumeInt(density*Static Enthalpy)@domain worked. I am able to arrive the Energy in Joules. I have some other problem will post as new thread.
energy function, integral computing, porous domain, specific heats, temperature dependent
JANAF Coefficient of Air for Specific Heat Calculation. rhoCentralFoam cyril2304 OpenFOAM Running, Solving & CFD 1 October 8, 2017 07:44
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
poor calculation with temparture-dependant specific heat ryanmoser FLUENT 3 January 3, 2013 01:32
CFX doesn't continue calculation... mactech001 CFX 6 November 15, 2009 21:25
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
