Energy calculation through inlet and outlet face |
November 29, 2017, 13:31 |
VB
Rep Power: 9 |
I have an Inlet face where fluid at 500°C at the rate 1 Kg/s is given as input. Outlet boundary condition is 0 Pa relative pressure. Inlet and outlet face area are 2 m^2.
How do you calculate the Energy fed at Inlet face and Energy exited at oulet face in Joules? may be for each time step? I am doing transient simulation with time step 20 sec. Total simulation time for 5 hr. |
November 29, 2017, 13:52 |
Rep Power: 32 |
You have to define what kind of energy you are accounting for.
If you want to account for total energy (internal + flow work + kinetic energy + etc), I would use Total Enthalpy, then Energy at inlet = Time Integral (from 0 -> 5hr) of massFlowInt(Total Enthalpy)@Inlet Energy at outlet = Time Integral (from 0 -> 5hr) of massFlowInt(Total Enthalpy)@Outlet Not sure how valuable those integrals are for open systems since I usually work with energy rates; therefore, no need for the time integral. |
November 29, 2017, 14:07 |
#3 | |
VB
Rep Power: 9 |
December 4, 2017, 16:23 |
Rep Power: 32 |
Difficult to answer w/o every detail about your boundary conditions.
To be able to convert the time integral to a "number of time steps" (not iterations) times "Delta Energy Flow", you must be certain that every variable involved in the calculation of the Delta Energy Flow is constant in time. Are you certain of this ? My first initial response would be No until a careful review of your setup is done. |
energy function, inlet and outlet, inlet bc, outlet wall |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
