CFX Harmonic Balance Stator-Rotor Interaction |
November 30, 2017, 09:40 |
Brambilla Fumagalli
Good Morning
I am a master student that is studying the stator-rotor interaction in an hp turbine stage (22 stat X 25 rot blades). I already set up the phase lag time integration unsteady solution and now I'd like to see the Harmonic Balance in term of performance and computational time. I read the Help of CFX but it tells only how to set up the blade flutter case. Does anyone have any suggestion on how to set up the Harmonic Balance method for un unsteady stage simulation? P.S. I just want to simulate the fluid mechanics, I have no interest in mechanical response of the blades. Thanks in advance. |
December 4, 2017, 16:27 |
Rep Power: 32 |
The only supported (documented) use case for Harmonic Balance is the Blade Flutter case.
You must wait until the stator-rotor use case is released. |
May 22, 2018, 10:19 |
#3 | |
NAVEEN KUMAR
Thanks in advance |
CFX pressure in Simulations problem | nasdak | CFX | 1 | April 14, 2010 13:22 |
Harmonic Balance CFD | cfdhb | Main CFD Forum | 0 | March 27, 2010 13:19 |
PhD using CFX | Rui | CFX | 9 | May 28, 2007 05:59 |
CFX 10 VS CFX 11 for combustion | Jonathan Lemay | CFX | 2 | May 9, 2007 11:58 |
Harmonic Balance (Frequency Domain) Euler CFD | Manish | Main CFD Forum | 11 | December 1, 2005 18:20 |
