January 25, 2018, 05:52 |
turbulence
Davide
Rep Power: 10 |
Hi, I would simulate the fluid dynamic of a break system inside the tire of a car of F1.... Before I simulated the aerodyamic of the all the car without the break system (the tire is closes laterallay without the wheel rim), then i would simulate only a box with the tire with the break system. In this box I put the velocity inlet profile that I exported as BC profile from the previous .res in the corresponding isoclip of the box inlet. Altough how I can set the turbulence (the turbulence kinetic energy and the turbulence eddy frequency) at this inlet box?? How I can export these variables and then how I can import in the second case?
Turbulence postprocessing | Mohsin | FLUENT | 2 | October 3, 2016 14:18 |
Turbulence length scale | Leonpolou | FLUENT | 2 | January 23, 2013 07:26 |
How to implement turbulence in one Solver??? | vahid.najafi | OpenFOAM Programming & Development | 0 | July 29, 2012 05:46 |
Code release: Flow Transition and Turbulence | Chaoqun Liu | Main CFD Forum | 0 | September 26, 2008 17:15 |
How's going on with Turbulence Research? | Daniel | Main CFD Forum | 1 | June 20, 2008 23:44 |
