Extracting data from a contour at various locations |
February 6, 2018, 10:51 |
Conor
Hi all,
I'm relatively new to CFX and I have a question regarding obtaining data from results. I sketched an airfoil in geometry, applied the meshing and setup and ran the solution. I now have results as per the image below. What I would like to do next is pull velocity and pressure data from various points along the airfoil. What's the best way to do this (add contours)? Thanks. |
February 6, 2018, 16:48 |
Rep Power: 143 |
Define your points on the airfoil. This can be done many ways. Then go file/export and get a CSV file, or use the points in the calculation spreadsheet tab, or use the points in CEL expressions. CFD-Post is quite flexible and can process the data in many ways.
February 6, 2018, 17:08 |
Gert-Jan
Rep Power: 27 |
If you want to extract pressure along the air foil, I would suggest to create a polyline as a boundary intersection. There select, the airfoil and the plane that you currently use to plot velocity.
If you have done that, you will obtain a line that you can use to plot pressure. Velocity will be zero, since you're on the wall. (with Hybrid values) |
data pulling |
How to extract data for contour plot? | Farid | CFX | 9 | April 3, 2017 19:07 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
extracting data in tecplot | peter | FLUENT | 0 | September 24, 2008 11:11 |
Extracting Post Data to a Text File | Ram | CFX | 3 | March 3, 2006 06:20 |
