surface tension
Old   September 17, 2003, 10:41
Default surface tension
Jennifer Haque
I wondered if anyone could advise me on how to decide when to use the effect of surface tension. If you have a situation where there is an air-water interface, do you use the surface tension effect?
Look foward to hearing from you.
Regards Jennifer
Old   September 19, 2003, 23:26
Default Re: surface tension
Jeff
Jennifer,
Assuming you're dealing with free surface flows here....
If you think about the surface tension effects in a test tube where the water wets the walls forming a maniscus, there is a deviation in the surface shape on the order of millimeters. If you are simulating something like bubbles or droplets where the shape of an individual droplet is important to your results, or a channel on the order of a few cm, then the surface tensions effects may be important. If on the other hand you're dealing with say channel flow of water in a 1m wide duct or mixing tank, then the surface tension effects are probably not important.
Jeff
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
continuum surface tension model yukn Main CFD Forum 0 October 8, 2011 06:43
Surface Tension Test Cases sega OpenFOAM Running, Solving & CFD 2 March 8, 2011 12:19
Surface Tension Force Model Miguel CFX 7 October 2, 2006 05:30
