memory problem in solver
Old   October 5, 2003, 13:21
Default memory problem in solver
rao
Can any one help me ! I am trying to run a simulation, but I got this error message: Data Type Kwords Words/Node Kbytes Bytes/Node
Real 384703.4 458.29 1502747.6 1833.15
Integer 162545.0 193.64 634941.6 774.54
Character 1900.8 2.26 1856.2 2.26
Logical 15.0 0.02 58.6 0.07
Double 24.0 0.03 187.5 0.23
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| *** Run-time memory configuration error *** |
| Not enough free memory is currently available on the system. |
| Could not allocate requested memory - exiting! |
But the computer has 3Gb memory ! what is going on here !
Old   October 6, 2003, 02:40
Default Re: memory problem in solver
Edoret
Hi Rao, (1)How many cells do you have? (2)What are the machine specification? (3)What is the physics/chemistry of the model? (4) What is the mode of the license access?
Answers to these questions will give us a basis to compare notes or comment.
regards. Eldoret
Old   October 6, 2003, 04:43
rao
I am running Windows 2000, and as adiministrator, I am simulating air flow over an aerodynamic object.
Old   October 6, 2003, 06:14
Eldoret
I guess this is a turbulent flow & single phase, is that right?? How about the numerics?
Eldoret
Old   October 15, 2003, 14:58
Neale
Rao,
The flow solver is trying to allocate:
1502742.6 + 634941.6 + 1856.2 = 2139540.4 KB.
I single process in Windows 2000 cannot allocate more than 2GB. Ask your service rep for a parallel key so you can split your job into a 2 process parallel run. That may work.
Neale
Polyflow Simulation with ViscoElastic Model memory problem sid2909 FLUENT 0 May 10, 2010 05:29
Polyflow Simulation with ViscoElastic Model memory problem sid2909 ANSYS 0 May 10, 2010 05:27
Problem with implicit unsteady solver CCMuser STAR-CCM+ 2 March 3, 2010 11:20
gridgen memory allocation problem ziad Pointwise & Gridgen 5 February 27, 2010 20:16
solver error #001100279. Memory Problem Sam CFX 5 March 17, 2004 00:17
