Equation of state for water
Old   November 6, 2003, 13:31
Default Equation of state for water
Atit Koonsrisuk
I would like to model the flow that density of water (in liquid state) can vary. I read in 'Solver Theory' that CFX equipped with Redlich-Kwong and Vukalovich Virial equation of state. I think that water might be modeled by these equations. However I have no idea how to find the option for these equations in CFX-Build. Can anyone tell me where it is and how to set it up? Thank you very much.
Atit Koonsrisuk
Old   November 6, 2003, 17:41
Default Re: Equation of state for water
Neale
These are only available as RGP files in CFX-5.6. You can use them in CFX-Pre by loading hitting the file button in the materials selector and then loading the two materials files. The Steam RGP files may not contain the data for the right pressure and temperature range you need though. In that case you need to contact your service rep to get the right RGP file.
Neale
Old   November 9, 2003, 13:41
Atit Koonsrisuk
I would like the density of water to vary in the simulation. However the equation of state that I have is the non-linear equation of density. How can I enter the equation of state in CFX-Build instead of follow your suggestion? Because I have only CFX-5.5.1. Or do you have any other suggestion. Thank you.
Atit
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
