March 22, 2018, 01:37 |
CEL error
Vipul Veer
Rep Power: 8 |
A problem has been occured as following:
"Bad expression value 'Power N' detected in parameter 'Expression Value' in object '/FLOW:Flow Analysis 1/OUTPUT CONTROL/MONITOR OBJECTS/MONITOR PO8NT:Power'. CEL error: The following unrecognised name was referenced: torque_Z. |
March 22, 2018, 02:27 |
Maxim
Rep Power: 12 |
I think the capital "Z" is incorrect. Try "torque_z()@patch".
March 22, 2018, 03:31 |
Thanks Maxim
Vipul Veer
Rep Power: 8 |
I will try your suggestion and let you know here. Thank you.
March 22, 2018, 03:44 |
M
Rep Power: 12 |
To avoid typos, you can always hit right mouse button on the writing space whenever you type an expression, there you can directly chose from variables/locators and so on and use correct names.
March 22, 2018, 04:11 |
An error has occurred in cfx5solve
Vipul Veer
Rep Power: 8 |
We are having problem in solution part which is stated as below :
"The ANSYS CFX solver exited with return code 1. No result file has been created.' |
March 22, 2018, 04:18 |
M
Rep Power: 12 |
You might want to start a new thread for that and add some details. The error code is no help, post the errors that occur before this message or your complete .out file.
/edit: I see, you already did. As I said, you must add more details on the error. |
March 22, 2018, 09:03 |
Error #333100220 has occurred in subroutine Out_MemPar
Vipul Veer
Rep Power: 8 |
This message states the error as below: The allocated memory exceeds the system memory on 1 host(s). the logical expert parameter "enforce system memory limit" controls weather this is a fatal error. The current setting is : fatal Allocating more than the system memory may result in slow or unreliable operation and is not recommended. |
March 22, 2018, 09:06 |
Maxim
Rep Power: 12 |
the message says what the problem is: your system does not have enough memory. How much RAM does your workstation have?
Describe your whole project - maybe with some screenshots - maybe there's a way to simplify the project to save memory... |
March 22, 2018, 11:07 |
#9 |
M
Rep Power: 12 |
As it states, the automatically allocated memory exceeds your workstation memory. Either move the simulation where you have more memory available or try to reduce memory by Execution Control -> Solver -> Solver Memory. As you exceeded by 251%, you must use factor as low as 0.4 to come to the value available. Try 0.39 to be sure. I doubt cfx will run with that, but if its a small simulation, it might work?
March 23, 2018, 01:19 |
Error has been solved
#10 |
Vipul Veer
Rep Power: 8 |
We have reduced the use factor as well as mesh sizing. Error is solved for now. Thank you Maxim and AtoHM.
March 23, 2018, 01:48 |
Another error occured in subroutine ErrAction
#11 |
Vipul Veer
Rep Power: 8 |
There are errors in CFX solver.
Floating point exception: overflow. Stopped in routine FPX: C_FPX_HANDLER |
March 23, 2018, 04:13 |
#12 |
Rep Power: 143 |
March 23, 2018, 23:26 |
An Error in CFX solver
#13 |
Vipul Veer
Rep Power: 8 |
For CFX runs launched from workbench, the final location of directories and files v generated may differ from those shown.
March 24, 2018, 04:56 |
#14 |
Rep Power: 143 |
Yes, Workbench does that. Most of the experienced members of this forum run CFX from the CFX launcher, not workbench so you have control over this (and control over many other things as well).
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
