How to calculate the fluid mass flow at the exit |
March 28, 2018, 06:39 |
Shuai Wang
Rep Power: 9 |
In CFX ,I want to calculate the fluid mass flow rate at the exit interface(Outlet). I set up the expression "Water.massflow@Outlet" in Monitor.Will this achieve my goal? In addition,what can I do the same thing in CFX Post?
March 28, 2018, 06:48 |
Gert-Jan
Rep Power: 27 |
You don't need to create special monitors for this in Pre.
In the solver manager this information is already available. You just need to make it visible by creating a new monitor plot and then select FLOW>BOUNDARY>Outlet. |
March 28, 2018, 07:16 |
urosgrivc
Rep Power: 11 |
Yes you can monitor it like you have vrote. And monitors are most usefull for knowing if your solution is realy converged enough.
In post you can aither evaluate this expresion which you have already created in pre and will be available in post also. Or you can use the function calculator which is wery convinient for calculating other stuf in post asveal. https://www.sharcnet.ca/Software/Ans.../NHFIFMEM.html |
March 28, 2018, 07:28 |
Shuai Wang
Rep Power: 9 |
Tkanks! It's really more convenient.
mass flow inlet and pressure outlet with target mass flow rate | Zigainer | FLUENT | 13 | October 26, 2018 05:58 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Exit Corrected Mass Flow Rate Mesh Sensitivity Study | s__s__s | CFX | 4 | July 20, 2016 11:46 |
Mass flow discrepancy | BenMUC | CFX | 3 | May 2, 2014 03:29 |
