March 29, 2018, 21:07 |
how to calculated the mass boundary flow
Shuai Wang
Rep Power: 9 |
I have a question about the calculation of mass flow in CFX Solver .
There's only a single fluid (water) at the entrance(Inlet) of my model, and the water temperature is 293.15K, the water density is 997 kg/m3(constant), the water velocity is 3.981e-5 m/s(constant), and the area of the Inlet interface is 4.1755e-4 m2.But the mass boundary flow on Inlet (water) is 5.66784e-6 kg/s in CFX Monitor. I want to know how to calculated the mass boundary flow on Inlet (water) in CFX. I can't calculate the same results manually. |
March 30, 2018, 01:09 |
urosgrivc
Rep Power: 11 |
1) This wlues are quite small so be sure to use double precision.
2) mesh quality and size (actual surface CFD solver uses is determined by the mesh not geometry) so check if the area you use for hand calculation difers from mesh inlet area gretely or is it prety much the same. You can check the exact area of your meshed inlet in cfd post and compare it to true size, is it a bit different? 3) Convergence, check domain imbalances if these are all ok than the result should be simmilar to manual calculation in this case |
March 30, 2018, 02:01 |
Shuai Wang
Rep Power: 9 |
Thank you for your advice.I'm going to check it out one by one.
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
Mass flow rate boundary condition with negative values | ashtonJ | CFX | 3 | November 26, 2014 05:21 |
CFX13 Post Periodic interface | EtaEta | CFX | 7 | December 8, 2011 17:15 |
