High-range Real Gas Liquid/Gas Mixing Problem
Old   April 11, 2018, 18:32
Default High-range Real Gas Liquid/Gas Mixing Problem
artfoster
bicklevov is on a distinguished road
I am trying to get a model to converge that uses oxygen with a wide range of pressures and temperatures without going to a 2-phase model. I am modeling liquid injection into a hot gaseous flow.
I have previously worked with the RGP table feature which works well by approximating the liquid and gas Cp and densities, and has been relatively accurate for the purposes I need, as long as I stay well away from the critical point (have kept pressures high).
I realize there is a FORTRAN RGP table generator that does not cluster points around the critical point, and a Python RGP table generator unique to 18.2 that does. Neither of them seem to work once I drop pressures in the model that bring me close to the fluid critical point.
Is there any way with a Peng-Robinson or Redlich-Kwong model to try and model this mixing? I have read the ANSYS model and have set the expert parameter realeos liquid prop to 2, but densities in the cold inlet (which I am approximating to be liquid) are still too high. I am making the overall equation of state a gas.
bicklevov is offline   Reply With Quote
Old   July 22, 2018, 03:46
Yafei Li
lyfflynice is on a distinguished road
Dear Bicklevov,
How to use the RGP file define the liquid properities? can you give me a format or example file? I will appreciate it!
Best regrad!
lyfflynice is offline   Reply With Quote
mixing fluids, real gas, tablegeneration
UDF for thermal conductivity relation of nano fluid ngonbadipoor@yahoo.com Fluent UDF and Scheme Programming 29 April 1, 2017 03:02
UDF velocity profile willroca Fluent UDF and Scheme Programming 2 January 10, 2016 03:13
[REQUEST HELP] Fluent 15.0 using NIST real gas model Reivax FLUENT 0 June 16, 2015 11:00
error message cuteapathy CFX 14 March 20, 2012 06:45
Sod shock tube problem with real gas effects ganesh Main CFD Forum 0 October 17, 2006 01:22
