Define decay constant of an additional variable
Old   January 29, 2004, 19:15
Default Define decay constant of an additional variable
jim
Does anyone know how to define a decay constant for a additional variabe in cfx5.6? I am trying to simulate the transport of a chemical which can self-decay in the reactor(decay at a constant rate). I set this chemical as an additional variable, but do not know where to set the decay rate.
Could you please give me some suggestions on how to start such a simulation?
Thanks!
Old   January 30, 2004, 02:50
Default Re: Define decay constant of an additional variabl
Pascale Fonteijn
You should define this as a negative source term, which should be a function of the residence time (= age).
Thus, first you have to define an additional additional variable called 'age' (see below). Then, you have to define a subdomain, in which you can define the source terms. The decay rate of zero order will be something like -constant*age.
You should do this in Pre.
Pascale
<Pre\>
LIBRARY:
ADDITIONAL VARIABLE: age
Option = Definition
Units = [ s ]
Variable Type = Volumetric
END # ADDITIONAL VARIABLE: AGE
END # LIBRARY:
DOMAIN: Domain 1
FLUID MODELS:
Option = Transport Equation
END # FLUID MODELS:
END # DOMAINomain 1
END # FLOW:
FLOW:
DOMAIN: Domain 1
SUBDOMAIN: Subdomain 1
Coord Frame = Coord 0
Location = Assembly 1
SOURCES:
EQUATION SOURCE: AGE
Option = Source
Source = 1 [s s^-1]
END # EQUATION SOURCE:AGE
END # SOURCES:
END # SUBDOMAIN:Subdomain 1
END # DOMAINomain 1
END # FLOW:
FLOW:
SOLVER CONTROL:
EQUATION CLASS: av
ADVECTION SCHEME:
Option = High Resolution
END # ADVECTION SCHEME:
CONVERGENCE CONTROL:
Physical Timescale = 100 [s]
Timescale Control = Physical Timescale
END # CONVERGENCE CONTROL:
END # EQUATION CLASS:av
END # SOLVER CONTROL:
END # FLOW:
Old   January 30, 2004, 03:16
jon
You could make the assumption that its a first order reaction and solve the ODE to get concentration in the form of:
c(t)=c0*exp(-k*t)
The constany k, calculated will be the constant in Pascale's above message.
By the way, I think that the above source should be set to density of fluid for a volumetric AV or 1.0 for a specific source. Above you have 1.0 for a volumetric source (which is fine for fluid density=1.0)
Old   January 30, 2004, 06:52
jon
Old   January 30, 2004, 06:54
jon
Sorry, I am an idiot.
Pascale was right. It is a source of 1.0 for volumetric sources and density for specific. Sorry.
Old   February 2, 2004, 11:14
jim
Hi,Pascale and jon
Sorry for the late reply! Thank you so much for your comments. Those are very helpful for me. I will try those today.
I have two questions regarding to your comments:
1. In Pascale's post,source term was defined as: Source = 1 [s s^-1] I am wondering if the unit should be s^-1?
2. Another question is: It seems that modelling the first order decay is much more easier that modeling other orders. However, some of my decay kinetics are second order or half order. Can I directly set input in cfx-pre? if no, how to do it?
Thanks again!
Best wishes!
Jim
Old   February 5, 2004, 16:15
Pascale Fonteijn
1) I copied it from CFX and it works fine for me.
2) Sorry, I do not see why it is easier to use 1st order than 2nd order. In 1st order your source term contains k1*C, in 2nd order it contains k2*C^2. You have to change the units of your constants k1 or k2 to obtain kmol/m^3/s.
Pascale
Old   February 8, 2004, 21:43
jim
Thanks a lot, Pascale,
I will try as you suggested.
Jim
UDF carbon conversion papteo Fluent UDF and Scheme Programming 1 August 18, 2011 07:32
Installing OF 1.6 on Mac OS X gschaider OpenFOAM Installation 129 June 19, 2010 09:23
use additional variable for CO concentration MinJaeHong CFX 0 August 25, 2008 05:14
How to delete additional variable in CFX Pre Ahlo CFX 0 August 21, 2008 12:34
Additional Variable - Diffusive Transport Equation RadheShyam Das CFX 3 October 18, 2007 12:35
