SIMULATION??????????????
Old   May 14, 2004, 11:40
Default SIMULATION??????????????
Zaher
Hi users,, I am using CFX 5.6 and I am simulating sloshing. I have a tank with 2 m in length and 2 m in diameter with a baffle inside it (to be set on a truck). The baffle has two openings, one in the top and the other in the bottom. I did't draw the walls, I just draw the fluid domain. I defined the baffle as a space (I imported it from Autocad). Then, I defined a mixture as my fluid ( air at 25 C and water at 25 C) with an approperiate mass fractions. After that I defined the bounding surfaces as walls and gave them a velocity with respect to time (transient) to simulate the tanker movement. However, I got negative pressure on the baffle and even inside the domain. So do you think that my simulation is rong??? Thanx in advannce,,,, Zaher
Old   May 23, 2004, 00:45
Default Re: SIMULATION??????????????
Jeff
See my reply to your previous post below....
Why my simulation not agree with the wind tunnel experiment zhaowei CFX 4 July 11, 2015 03:36
Solar Radiation in OpenFOAM plainstyle OpenFOAM Running, Solving & CFD 15 July 8, 2014 04:43
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 10:44
Continuous vs interrupted simulation sega OpenFOAM Running, Solving & CFD 4 November 3, 2008 14:29
strange simulation error Ralf Schmidt FLUENT 2 May 4, 2007 13:02
