a problem in boundary condition
Old   May 19, 2004, 03:02
Default a problem in boundary condition
feng
I want to simulate a centrifugal pump with a pipe inlet,at present, I only want to calculate only one channel(I have six blades),so the inlet is a sector.the two periodic boundary meet together at the center line of the pipe.when I have a look at the result,the static pressure at the cneter line is as low as -6MPa,so I think the boundary condition may be not correct.who can give me some suggestions?
thank you
Old   May 19, 2004, 11:47
Default Re: a problem in boundary condition
centaur_ks
set that single line periodic with itself.
Old   May 21, 2004, 02:39
feng
i have tried what you said,but there was a piece of error message,which was, "attachment must refer to at least one flux element"
inlet velocity boundary condition murali CFX 5 August 3, 2012 08:56
Transient Simulation: Boundary Condition Problem Shafiul CFX 7 January 11, 2011 16:40
problem about periodic boundary condition in Fluent winnawinna FLUENT 0 December 28, 2010 23:32
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
boundary condition problem - NEED HELP rave Siemens 2 August 7, 2007 02:19
