Unit of Expression
Old   May 27, 2004, 01:40
Default Unit of Expression
Fing
I would like to input a viscosity expression but I can not how to solve the problem of the unit of the expression. My expression will be:
M_u = exp(1.2 - 2.9*log_e(4.5*sstrnr))
where M_u is dynamic viscosity, sstrnr is the strain rate. How can I solve the unit problem?
Thanks,
Fing
Old   May 27, 2004, 03:41
Default Re: Unit of Expression
matej
What I allways do is simple trick. in logs and exps multiplying the variables with 1 of reciprocal unit, and multiplying the result with a 1.0 with the desired unit.
if you have a some variable A [m^2] in a exp(A), and you want the result B in [K] using formula B= 100.0*exp(A), (really silly example), what you do is: B=100.0 [K] * exp(A *1.0 [m^-2])
and that's it!
matej
Old   May 27, 2004, 10:17
Default Thank you, matej
Fing
Thanks, matej.
Regards,
Fing
Problem About Running Fluent In Linux mitra FLUENT 18 June 20, 2019 02:11
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
Lift, Drag Vs time chart,calculations Jamesd69climber CFX 8 February 17, 2005 17:23
Creating, loop or iteration using expression edito Jan CFX 3 July 28, 2003 11:01
