Simple Poiseuille flow
Old   May 27, 2004, 10:58
Default Simple Poiseuille flow
Maggie
I am having problems with simulating a simple Poiseuille flow in a small pipe. At the boundary 'Inlet' I prescribe the velocity in 3 directions (0 in both y- and z-direction and 2*Vaverage*(1-r^2/R^2) in x-direction). At the outlet the relative static pressure is set to 0 Pa, and at the wall a 'no slip' condition is priscribed. As a result velocities of about 4e-3 m/s in y- and z-direction are created by CFX 5.6. How can I create a Poiseuille velocity field in the entire pipe (so velocities in y- and z-direction becomes 0 or in the order of 1e-6)?
Lid-Driven cavity flow with SIMPLE method luckyxu Main CFD Forum 6 November 9, 2011 07:17
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
SIMPLE algorithm for variable density flow mauz Main CFD Forum 1 May 15, 2009 15:13
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
simple method for compressible flow saeed Main CFD Forum 0 April 24, 2003 02:20
