Difference between homogeneous and in-homogeneous free surface model. |
July 25, 2018, 04:11 |
Taiwan,new north city
Rep Power: 8 |
Dear all,
I am working on a multi phase problem of oil/air separation by gravity. this phenomena used in oil injected compressor tank (horizontal tank). i tried to solve this problem by (volume of fluid and homogeneous and in-homogeneous free surface model approach). please clarify the following questions. Boundary condition: Domain : air domain and oil domain Interface : one fluid-fluid interface Inlet : air/oil mixture Outlet 1 : air outlet (opening pressure condition) Outlet 2 : oil outlet (opening pressure condition) Questions: 1. I am confusing with homogeneous and in-homogeneous free surface model.which model to select? 2. Homogeneous and in-homogeneous model results are different with the same boundary conditions and mesh. 3. solution is not converging Thanks in advance... |
August 1, 2018, 03:27 |
Thomas
Rep Power: 12 |
Questions:
1. I am confusing with homogeneous and in-homogeneous free surface model.which model to select? It is well described in the CFX Theory Guide 2. Homogeneous and in-homogeneous model results are different with the same boundary conditions and mesh. I assume your solution is not converged, I wouldn't invest much time in comparing 3. solution is not converging Try to change the numerical setup between segregated and coupled, if air is compressible use incompressible setup first |
August 1, 2018, 05:09 |
Rep Power: 8 |
Thanks Thomas,
i have changed a numerical setup from segregated to coupled as per your suggestion. |
