ANSYS CFX 14 on UBUNTU 12.04 64bit: PARALLEL ISSUE |
December 26, 2012, 19:45 |
David
Rep Power: 13 |
hi guys,
I'm running cfx 14, pre post solver and turbogrid without any problems on a 6 core i7 machine with ubuntu 12.04 64 bit. when I try to run the same case in local parallel i get this issue: An error has occurred in cfx5solve: A ANSYS CFX Partitioner executable is required for this run, but none is available. I already looked for this issue but i found nothing usefull...can someone help me please? thanks in advance! p.s from x86info i get this: WARNING: Detected SMP, but unable to access cpuid driver. Used Uniprocessor CPU routines. Results inaccurate. |
December 28, 2012, 05:24 |
David
Rep Power: 13 |
Nobody can help me?
Can someone tell me if is able to run CFX in parallel on ubuntu 12.04 64? Can someone tell me which version of linux 64 has no problem running cfx solver in local parallel? THANKS! |
December 28, 2012, 06:15 |
Rep Power: 143 |
Have you read the supported linux releases in the documentation?
December 28, 2012, 06:43 |
David
Rep Power: 13 |
yes, I know that few OS are supported...anyway I would like to understand is someone can run a local parallel run on an another linux os.
I would like also to understand which are the post-installation steps that has to be done in order to have a local parallel run. Thanks you in advance! |
August 7, 2013, 21:47 |
Anthony Nitski
Rep Power: 16 |
You should use -partitioner command line option when starting cfx5solve. And manually point to part executable, for ex. /ansys_inc/v145/CFX/bin/cfx5solve -partitioner /ansys_inc/v145/CFX/bin/linux-amd64/int64/partitioner.exe -def $defFile -start-method "Platform MPI Distributed Parallel" -par-dist $nodes -size 1.4 $ini. Tested on Debian 7.1.
November 25, 2013, 07:31 |
luigi
Rep Power: 13 |
Hi everybody. I've found the same problem with CFX14 and debian wheezy. I tried to follow what suggest u22 but it doesn't work. this is the error: "Use of uninitialized value in string eq at /ansys_inc/v140/CFX/bin//perllib/CFX5/Simulation/ConfigSettings.pm line 835". Someone can help me?
thanks |
August 9, 2018, 15:05 |
#7 | |
H. Omar
Rep Power: 13 |
Dear luigi, Did you manage to solve this problem? I have the same problem and I would like to know how you were able to solve it. Thanks. |
cfx, issue, parallel, partitioner, problem |
Problem in coupling CFX and Ansys for fluid-thermal sim. | Jordi | CFX | 21 | March 1, 2017 05:03 |
[ICEM] issue occur after extrude 2D airfoil mesh and convergence problem in CFX | shiyun | ANSYS Meshing & Geometry | 4 | May 9, 2012 19:55 |
Ansys cfx post issue | Ruchika | CFX | 0 | March 2, 2012 06:13 |
how well does CFX parallel scale? | danieru | CFX | 10 | February 29, 2012 09:20 |
ANSYS to acquire CFX | Fred | FLUENT | 0 | February 18, 2003 21:04 |
