NAME_MOD: Error finding variable "DIAMCLIP_FL1" |
August 16, 2018, 10:09 |
Thomas
Rep Power: 8 |
Hello everyone,
I am modelling the filling process of a bottle with water using the inhomogenuous MUSIG model for air entrainment and the AIAD model to differentiate between bubbles droplets and free surface. When starting the simulation I get the error Message: +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | NAME_MOD: Error finding variable "DIAMCLIP_FL1" | | | | | | | | | | | +--------------------------------------------------------------------+ I searched inside the installation directory of CFX according to this thread: NAME_MOD: Error finding variable "TSUPER" I was not able to find the exact variable there. I just found : DIAMCLIP which is a particle diameter. I assume DIAMCLIP_FL1 would be the particle diameter of one of my fluids (gas or water)? How do I supply the missing variable for the simulation? Thanks in advance for any help! |
August 16, 2018, 20:19 |
Rep Power: 143 |
CFX error messages are cryptic, and your guesses that it is referring to particle diameters look reasonable. I would suggest it might be looking for a clipping variable on the particle diameters. But exactly what the problem is and how to fix it is not clear.
I would suggest opening your case in CFX-Pre and checking that all the MUSIG and multiphase parameters are correctly set. See if you can find the missing parameter.
August 18, 2018, 07:59 |
Thomas
Rep Power: 8 |
I found the solution as I introduced an expression for the Interfacial Area Density using the ccl script:
FLUID PAIR: GasC | Liquid Surface Tension Coefficient = sigma INTERPHASE TRANSFER MODEL: Interfacial Area Density = AD Minimum Volume Fraction for Area Density = MinVFArea Option = Particle Model END The name was wrong and should be called CLIPPED INTERFACIAL AREA DENSITY. |
March 19, 2019, 10:21 |
John
Has the AIAD model been successfully added to the program?
March 20, 2019, 13:19 |
Thomas
Rep Power: 8 |
OpenFoam-1.6-ext Allwmake compilation error - one last barrier | Pat84 | OpenFOAM Installation | 15 | July 25, 2012 21:49 |
emag beta feature: charge density | charlotte | CFX | 4 | March 22, 2011 09:14 |
error in COMSOL:'ERROR:6164 Duplicate Variable' | bhushas | COMSOL | 1 | May 30, 2008 04:35 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 04:27 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
