XYZ Coordinate
Old   August 25, 2004, 13:56
Default XYZ Coordinate
RK
Hello:
I am using USTRN to write out Temperature values at all nodes in particular a block. With these temperature values, I would also like to write the X, Y, & Z values (which are distances and therefore it should be in units of meters) at the corresponding temperature value. Thus the output file created would look like as shown below; four column with particular values.
X/ Y/ Z/ T/
0.0/ 0.0/ 0.0/ 2.0E-03
I hope this makes some sense. Does any one know how to do the above?
Thanks in advance.
RK
Old   August 25, 2004, 23:33
Default Re: XYZ Coordinate
Jeff
Assuming that your are speaking of using USRTRN in CFX-4.....
Loop over the nodes in the block, or 3D Patch (this is the recommended method then you can re-block if you want to). Then access the arrays XP,YP,ZP to get the three coordinates of the cell center. Temperature is in the T array......
CALL IPALL('PATCH NAME','USER3D','PATCH','CENTERS',IPT,NPT,CWORK,IWO RK)
IPHASE = 1
DO I = 1,NPT ! Loop over all cells INODE = IPT(I) ! Get node index X = XP(INODE) ! Get X coordinate Y = YP(INODE) ! Get Y coordinate Z = ZP(INODE) ! Get Z coordinate TEMP = T(INODE,IPHASE) ! Get Temperature value WRITE(*,*) X,Y,Z,TEMP ! Write values out ENDDO
If you must loop over the block (instead of a USER3D patch) then use IPREC instead of IPALL (different parameter list), but you can only do one block at a time. I suggest you get in the habit of defining USER3D patches for your regions of interest as they can cover multiple blocks.
Jeff
Old   August 26, 2004, 03:27
RK
Jeff:
Many thanks for your help!
RK
cylindrical coordinate vs cartesian coordinate Lam FLUENT 10 May 11, 2013 13:05
CFD Software with Cylindrical and Spherical Coordinate cfd2010 Main CFD Forum 0 June 9, 2010 21:55
Cording Ground.for in Cylindrical coordinate J.H. Lee. Phoenics 2 March 28, 2003 04:28
coordinate frame Jackie CFX 2 March 6, 2003 00:22
Coordinate transforms and finite volumes Tony Keating Main CFD Forum 4 September 8, 2000 07:41
