Design Modeller error
Old   September 14, 2004, 02:40
Default Design Modeller error
HK
Hi All,
Why do I get this error msg:
"gtmGeometryServer_wb.exe has encountered a problem and needs to close. We are sorry for the inconvenience."
The software is sorry for me, I am sorry too!! What did I do wrong? It happened when I tried to mesh in design modeller.
HK
Old   September 14, 2004, 18:14
Default Re: Design Modeller error
Do you have closed surfaces? Singularities? Degenerate edges? Sliver surfaces? The mesher can handle normal geometries quite well, so no doubt you have some sort of challenging aspect.
Old   September 14, 2004, 21:38
HK
Hi Glenn When I imported some geometry into DM generated by ICEM (closed surface) some surfaces are missing which makes some holes in the domain.
Any idea why thats happening?
HK
Old   September 15, 2004, 18:19
I don't think ICEM can do parasolid export. How did you get the geometry from ICEM to DM?
The import process and the missing surfaces are almost certainly the cause for the problem. Importing geometry accurately and completely is always difficult.
Glenn
Old   September 15, 2004, 19:13
HK
Check Icem5:file>>export geometry>> either Parasolid or IGES.
I find it easier to make the geometry in ICEM and to make the mesh in DM, so I thought I would combine.
HK
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
