CFX 5.7 rotational mesh deformation?
Old   October 7, 2004, 17:19
Default CFX 5.7 rotational mesh deformation?
NymphadoraTonks
I've been playing with tut 20 ... the presure relief valve.
Can CFX 5.7 handle rotation of mesh cavities?
E.g. smaller cube cavity rotating within larger mesh cube?
In this case the geometric centre of the cavity would not translate but would rotate.
TIA
Old   October 7, 2004, 18:11
Default Re: CFX 5.7 rotational mesh deformation?
It sounds like you can describe your mesh with a stationary and a rotating mesh domains. Therefore you can model what you describe.
Old   October 8, 2004, 04:11
NymphadoraTonks
Not quite ... I should have been a bit more specific.
The actual problem were an interested in is more akin to a high-aspect-ratio hexagonal cavity oscilating within a larger high-aspect-ratio hexagonal fluid domain.
I.e. complete rotation isn't possible and in fact we are only interested in a cyclically repeating partial rotation (~30*) not a 360* rotation.
TIA
Old   October 8, 2004, 04:13
NymphadoraTonks
God ... need more coffee:
s/hexagonal/hexahedral
Old   October 9, 2004, 13:20
NymphadoraTonks
Hmmm ...
Unfortunately CEL specified mesh motion only allows for translational motion.
I'm busy investigating User Fortran spec'ed mesh motion as an alternative.
Old   October 10, 2004, 18:24
Don't forget you can do mesh deformation with CEL. If you can describe your motion with a CEL function this is often much easier to apply than fortran.
Old   October 11, 2004, 04:36
NymphadoraTonks
You can specify *surface* motion with CEL with the volume mesh being automagically deformed as appropriate. (i.e. tut 20 A)
But as I understand it you cant explicity specify volume mesh deformation with CEL?
Or am I missing something?
Old   October 11, 2004, 18:35
Yes, you can explicitly define volume motion - as long as you can define the deformation at every node with a CEL function. You can also mix it up, for instance have a subdomain with the volume mesh explicitly defined and the remainder of the domain with the surface mesh defined and the remainder of the volume mesh determined by CFX using the Laplacian smoother.
[ANSYS Meshing] Internal gear pump mesh deformation CFX V11 Malik77 ANSYS Meshing & Geometry 0 August 22, 2011 10:22
cfx mesh problem... mactech001 ANSYS Meshing & Geometry 0 November 5, 2009 02:19
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
Problem with rotational mesh deformation: Part II NymphadoraTonks CFX 2 November 4, 2004 03:05
