Boundary-static temperature
Like Tree1Likes
  • 1 Post By urosgrivc
Old   October 3, 2018, 04:32
Question Boundary-static temperature
STC Amine is on a distinguished road
Hello ,
How to introduce the inlet water temperatures as tabular form in a static temperature ?
Cordially.
STC Amine is offline   Reply With Quote
Old   October 3, 2018, 07:12
Gert-Jan
Gert-Jan will become famous soon enough
What kind of table do you want to make? Do you want to describe the temperature as a function of coordinates?
In other words: can you explain what problem you are working on?
Gert-Jan is offline   Reply With Quote
Old   October 4, 2018, 02:41
urosgrivc
urosgrivc is on a distinguished road
this can be done in multiple ways;
[1] you can make an expression which depends on location
[2] You can import data via user function as a table and than use an expression to set up your boundary condition
[3] You can import data directly to your CFX via ->Tools->initialize profile data
you are then able to interpolate or use all this data in expressions also (very powerful tool)
[4] there are definitely some other ways also...
So which one you use depends on what you want to achieve and what type of data you have.
STC Amine likes this.
urosgrivc is offline   Reply With Quote
Old   October 9, 2018, 04:20
Thank you for your efficient and prompt attentions, what i want to do is insert the inlet water temperature as tabular expression in the heat transfer boundary.
Time (Hours) Te(°C)
08:10 10,4
08:20 11
08:30 11,1
08:40 16,1
08:50 15,4
09:00 13,9
09:10 14,7
09:20 13,5
09:30 13,6
09:40 13,9
09:50 13,9
10:00 13,8
10:10 13,4
10:20 14,1
10:30 14,6
Old   October 9, 2018, 04:54
urosgrivc
I think that option [2] from before is best for this:
Type this into google (user function cfx):
You first need to make a tab delimited text file like this;
numbers must be vith . (dot) (not ,coma)
0 10.4
60 11
120 11.1
180 16.1
240 15.4
320 13.9
380 14.7
Now you make a new user function called "historyT"
the first column will be [s] in this case, but can be whatever you like
the other one [C]
you right-click on the blank space (coordinate-value table will be blank at first) in the user function setup and import the text file.
the table will be filled with values now, this part is done,
Now you make a new expression named "Temperature_t":
Temperature_t = historyT(t)
to the expression the (t) term is aded vhich stands for time dependant.
now you insert this expresion into setings for inlet temperature
and voila temperature vill change acording to time
it will be linearly interpolated between values.
Old   October 9, 2018, 05:28
Time (Hours) Te(°C)
08:10 10,4
08:20 11
08:30 11,1
08:40 16,1
08:50 15,4
09:00 13,9
09:10 14,7
09:20 13,5
09:30 13,6
09:40 13,9
09:50 13,9
10:00 13,8
10:10 13,4
10:20 14,1
10:30 14,6
Old   October 9, 2018, 05:35
Thank you a lot for your valued assistance.
Old   October 9, 2018, 06:16
0 10.4
60 11
120 11.1
180 16.1
240 15.4
320 13.9
380 14.7
the other one [C]
Could you show me a demonstration!
Old   October 9, 2018, 06:33
urosgrivc
The first part to create user defined function...
http://cfd2012.com/cfx-user-functions.html
the second part is just an expresion
google it you will learn much more
enter expression, static temperature, temperature
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 09:21
CFX Spray Breakup Setup Spray_Ansys CFX 28 June 9, 2018 07:37
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 01:27
Low torque values on Screw Turbine Shaun Waters CFX 34 July 23, 2015 08:16
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
