Turbogrid and Negative volume
Old   December 23, 2004, 18:53
Default Turbogrid and Negative volume
Ali
hello everyone, I know that this is a repeated question. But I can not solve the problem of negative volume at Turbogrid. I have always negative volume and moving the points donot help (takes a lot of time and finally negative volumes). I also want to change the number of blocks at the shroud without hanging the nubmer at hub. Thank you for help. Happy holiday.. Ali
Old   December 24, 2004, 01:03
Default Re: Turbogrid and Negative volume
deLuther
I found for myself that I can get better mesh form ICEM as fast as from TurboGrid...maybe even faster - less blocks - less headache...
Old   December 24, 2004, 08:00
Ali
Thanks Luther, Does ICEM work with turbomachines? Ali
Old   December 24, 2004, 08:23
Reemull
Go to the Template pull down menu and then try flipping your topology and profile. You'll need to rearrange you points afterwards - however just do it roughly. Then check your grid for negative volumes. If you no longer have negative volumes go back in and tidy up your points.
That's how I generally solve the problem.
Roy
Old   December 24, 2004, 10:25
Ali
Thank you Roy, I just used Turbogrid from 1 week ago. I want to know what do you mean by "Template pull down menu" and would you explain how to perform this flipping..About arranging the point it takes a lot of time and does not work in my geometry. Ali
Old   December 24, 2004, 11:18
Reemull
In the bar along the top of the Turbogrid, there is a button called Template. If you click on it it will produce a menu - which includes the two flipping options I mentioned.
Cheers
Roy
Old   December 24, 2004, 15:24
Ali
Thanks Roy for quick response. I'm using Turbogrid 2.2 and there is no Tempelate button. What is the version that you use? Thanks again Ali
Old   December 28, 2004, 17:47
Ali
hello everyone again.. I'm using Turbogrid 2.2 and I get negative volumes. I moved control points and get no negative volume, but CFX solver says "there exists negative volume!!!" Anyone can help... Ali
Old   December 31, 2004, 12:30
Gang
If you use TG 2.2, I highly recommend you to get TG 2.2.1. There is big improvement from 2.2 to 2.2.1. Which topology do you use? One thing I think may help is to inspect mesh from hub to shroud. By default, TG only shows grid on hub, shroud, and one span location. Sometimes, mesh on those surfaces may look perfect but problem still exists at other locations.
Old   December 31, 2004, 17:54
Ali
Hello Gang, I use H-Grid and O-Grid for topology. I think the problem in my gemoetry that the blade have sharp cut. Around the tail and lead end the mesh intersect causing negative volume. I have TG 2.2 only. What you suggest? I also I can see a good mesh in BLADEgen how can I transfer it to CFX? Thanks.. Ali
Old   January 1, 2005, 11:26
  #11
Gang
TG 2.2.1 has a new feature to handle sharp cut LE or TE. You should give it a try. It's very possible that your problem will be solved by TG 2.2.1.
Maybe BladeGen file can be imported into CFX-Pre directly. If not, you can convert BladeGen file into CGNS format in CFX launcher. CFX-Pre can read CGNS file.
Old   January 2, 2005, 08:56
Default Thank you Gang
  #12
Ali
Thank you Gang for Reply and Happy NEw Year.. Ali
Old   August 18, 2016, 14:31
Have a nice time!
Ahmed Saeed Mansour is on a distinguished road
Hello , can anyone helps me to adjust the control points? the idea behind it?
Thanks
Ahmed Saeed Mansour is offline   Reply With Quote
Turbogrid negative volume Come Back jorge CFX 1 September 4, 2007 03:05
Negative Volume saurav pathak Main CFD Forum 6 September 1, 2007 11:26
negative volume in turbogrid lingo CFX 1 October 8, 2004 10:56
