solidworks--workbench
Old   February 17, 2005, 12:35
Default solidworks--workbench
Jack
Hello,All,
Since a geometry is not easy to build with Workbench directly, I use Solidworks to built 8 Parts first, and mate parts to be an sssembly. Then I import the geometry to workbench in parasolid format(*.x_t) or iges format. Now what I see is that 8 solids are generated. Can I merge these solids to one? or do I need to merge them?
This is the first time I do like this. I am not sure what I need to do when and after I import the geometry file? I would appreciate your kind advice!
Regards!
Jack
Old   February 17, 2005, 20:12
Default Re: solidworks--workbench
Derrek
Jack:
It depends on your application. I assume it is a CFD model? A few comments first, you can build geom easily in Workbench if you have DesignModeler. DM is the "geom" module in Workbench. It can be used as a standalone modeler or in conjunction with SW to simplify, add geom etc for analysis purposes. Also, it can be used to "merge/glue" geometry from CAD if necessary.
What module are you importing your parasolid file into, Simulation, CFX Mesh, or perhaps you have DesignModeler?
More info is needed before I can give some advice.
Cheers,
Derrek
Old   February 18, 2005, 11:25
Jack
Thanks,Derrek,
I am importing the parasolid file into DM and then to CFX Mesh. It shows that 'CAD model contains faces with small angles' and there are also some 'silver edges' exsisting. So I am trying to do some modifications to the geometry model in DM.
The geometry is an hydrofoil impeller. Maybe I need to rebuid the model with DM?
Thanks again
Jack
Old   February 19, 2005, 11:00
Derrek
JAck:
Go to Tools>Options>Common Settings>User Interface and turn on BETA options. This will expose Virtual Topology in CFX Mesh. This will allow you to merge areas together to eliminate some of the sliver surfaces.
It may be easier to rebuild it in DM. You have to weigh the options.
Derrek
Old   February 22, 2005, 11:59
Ian
I would merge them in SolidWorks into a single part. It's very easy to do.
ANSYS Workbench on "Uncertified" Linux Distros hsr CFX 289 April 20, 2023 09:23
PEM Fuel cell module meshes. ICEM vs workbench aarvay FLUENT 24 March 2, 2020 06:50
[ANSYS Meshing] Workbench 13: Structured Hexa Meshes rooftop ANSYS Meshing & Geometry 19 March 31, 2016 02:33
Importing Rhinoceros 3d model to SolidWorks george85 FloEFD, FloWorks & FloTHERM 21 March 5, 2014 05:19
Temperature contour as thermal condition in Workbench? nuothe11th ANSYS 0 April 23, 2010 12:11
