About timestep in transient mod
Old   March 3, 2005, 07:49
Default About timestep in transient mod
w0er
Using CFX5.7 for transient mod....How to define timestep??If it is the physical time that the flow passed the domain????
Old   March 3, 2005, 13:50
Default Re: About timestep in transient mod
Robin
Your timestep needs to be small enough to resolve the transient features of your flow. Generally this means that you should converge within 3 to 5 coefficient loops within your timestep.
A timestep equal to the resident time would be far too big.
Regards, Robin
Old   March 4, 2005, 12:06
Chien
Under a laminar flow simulation, what be the possible reason that would cause the solution to diverge with smaller timestep?
Old   March 5, 2005, 15:24
Jeff
Good guidance would be to start with the courant limit. This is the smallest element length divided by the expected velocity through that element (i.e. the time it takes a fluid particle to pass through one mesh element). For an accurate time marching solution, you certainly don't want anything larger than that.
Highly fluctuating oscillations may require an even smaller step size, but it's a good place to start.
Jeff
Old   March 6, 2005, 00:11
w0er
Thank you for your suggestions,,,
Old   March 6, 2005, 16:36
To answer Chien's question:
Smaller timesteps can lead to divergence as you can now resolve more flow features. For modelling a bluff body with a large timestep can just show a large wake, whereas the same model with a fine timestep can resolve the details of the oscillating vorticies in the wake. Resolving these vorticies is a tougher ask numerically than the bulk flow field, so if your simulation is not very stable it could cause divergence.
transient timestep ? amine CFX 2 June 28, 2008 19:22
transient timestep tony CFX 1 March 12, 2008 16:39
Timestep for transient simulation houman CFX 2 April 28, 2005 03:44
transient, parallel - problem with timestep Peter CFX 5 March 8, 2005 16:15
Timestep in transient flow Zaher CFX 2 March 13, 2004 02:48
