Error when creating a contour on a user surface |
Nicki
Rep Power: 0 ![]() |
Hi all,
I'm hoping you may be able to help me - I'm trying to plot a thermal comfort metric in a space (CFD Post, run in CFX) and keep getting the same error message popping up: WARNING 'Vertex' values for Variable 'UTCI3var' do not exist on Geometry /USER SURFACE:Occupied Surface. This UTCI3var is a section of the full equation based on air temperature, air speed, mean radiant temperature and humidity (included as an attachment for reference) which can all be plotted without issue on their own. Has anyone come across this before or have any advice on how to fix please? Thanks, Nicki |
Rep Power: 143 ![]() ![]() ![]() ![]() |
I don't know exactly what the problem is but on a surface the fluid velocity is zero by definition so check whether your function is valid with zero velocity. In particular, how is the "vair" variable defined and is it defined on a wall surface?
Erik
Rep Power: 23 ![]() |
I'm guessing you stripped all the units from the expression? Or else your expression would not work due to units not matching in all the terms.
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[ICEM] Automatic mesh generation script surface intersection problem | stuart23 | ANSYS Meshing & Geometry | 0 | May 13, 2011 01:10 |
user surface? | colins | CFX | 4 | December 15, 2003 07:58 |
CFX 5.5 | Roued | CFX | 1 | October 2, 2001 16:49 |
