Hi.
I wonder if someone has some suggestion for my problem. I created: Additional variable (through aldebraic equation) of type "unspecified": var1=Pressure var2=function(var1) My function is a CEL function which points to a fortran routine. The argument unit of this function is [Pa] and the results unit the same than var2. My problem is that I don't have access to "var2" in CFX post. The name of my function is not recognised. So I wonder if it's the right way to set an AV equal to a function, or if it comes from my fortran routine? Thank you for helping. Regards, Marko |
Problem setting C_MU_T with DEFINE_ADJUST | Andy | FLUENT | 3 | June 22, 2018 02:53 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
Problem in setting porosity region for rhoPorousSimpleFoam | run_cfd | OpenFOAM Pre-Processing | 1 | May 31, 2011 09:02 |
Problem setting C_MU_T with DEFINE_ADJUST | sarah_ron | FLUENT | 1 | February 24, 2005 12:11 |
Help setting up combustor problem | Tom | FLUENT | 0 | February 5, 2005 01:20 |
