Sample PBS script file for CFX job in Linux based HPC |
November 26, 2018, 00:55 |
Shubham
In order to submit a CFX job in Linux based HPC, while submitting the job using script file following error is generated:
/var/spool/PBS/mom_priv/jobs/7546.hn.SC: /usr/bin/modulecmd: No such file or directory /var/spool/PBS/mom_priv/jobs/7546.hn.SC: line 15: cfx5solve: command not found Kindly provide a sample script file |
November 26, 2018, 04:32 |
Rep Power: 143 |
You just need to sort some paths out. This is elementary script file work. Read the error messages and the problem is clear.
The first error says you are referring to a directory which does not exist. The second error says you called the cfx5solve executable but it could not find it. You need to define the full path to the cfx5solve executable file.
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc | ofslcm | OpenFOAM Community Contributions | 25 | March 6, 2017 10:03 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
