April 29, 2005, 11:00 |
Fatal error
Hi! I'm using CFX-5.6 and I'm having this error: edges do not match for face, can any one help me! I'm simulating a anular space, and the error it's in one of the bottom surfaces.
Thanks |
May 2, 2005, 11:35 |
Re: Fatal error
It depends on the mesh. If you have some "Periodic" boundary conditions, or "interfaces", the faces need to be the same, maybe the top and the bottom surfaces in your problem.
Try to check the mesh |
May 2, 2005, 13:34 |
Re: Fatal error
Thanks! I'll check it out!
polynomial thermophysical properties II | sebastian | OpenFOAM Running, Solving & CFD | 54 | November 21, 2019 07:12 |
CGNS Compiling | Diego | Main CFD Forum | 17 | December 21, 2014 01:40 |
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! | alban | Fluent UDF and Scheme Programming | 2 | June 8, 2010 18:54 |
[Netgen] Installation of Netgen in SuSE Linux 92 | edvardsenpriv | OpenFOAM Meshing & Mesh Conversion | 23 | January 16, 2009 06:12 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
