Floating Point exception "overflow" error in Oil inject twin screw compressor |
November 28, 2018, 01:10 |
Taiwan,new north city
Rep Power: 8 |
Hello Guys,
I am working on transient multi-phase simulation of Oil inject twin screw compressor (rotors clearance 0.036 mm) by Twin-mesh and CFX. I am getting "overflow" error at 35th and 40th time step. The following possible changes already made to solve "overflow" error: 1. Tried with k epsilon and SST turbulence model. 2. Different mesh size (max element size 1 mm and 0.8 mm and 2 mm) 3. Different inlet and outlet condition (pressure inlet and mass flow inlet, opening and static pressure outlet) 4. Homogeneous and in-homogeneous with and without free surface model and interface transfer 5. Coupled and segregated multi-phase coupling method 6. Tried with different relaxation parameter and memory allocation factor (expert parameter) 7. run in first order and high resolution 8. Tried with small time step Note: I tried all the above changes but still, I got over flow exactly at 35th time step with first order (advection, transient, turbulence) scheme. I got overflow exactly at 40th time step with high resolution (advection and turbulence) scheme and second order (transient) scheme. please someone help me with this "overflow" problem. I truly appreciated your help in advance. I have attached a image of overflow error for your reference. Thanks... |
icoFoam floating point exception (8) | leizhao512 | OpenFOAM Running, Solving & CFD | 7 | November 1, 2018 11:43 |
A floating point exception has occurred: floating point exception [Overflow]. | starlight | STAR-CCM+ | 4 | May 4, 2016 09:08 |
A floating point exception - SEM Model | yansheng | STAR-CCM+ | 1 | April 4, 2016 04:57 |
Floating point exception from twoPhaseEulerFoam | openfoammaofnepo | OpenFOAM Running, Solving & CFD | 1 | March 19, 2016 13:56 |
Floating point exception (core dumped) for GAMG solver | yuhou1989 | OpenFOAM Running, Solving & CFD | 2 | March 24, 2015 19:28 |
